Could someone help me understand how to remove the rows with blank values?
Good evening @Schreg,
Answer: filter the calculated table for only the non-blank “CalcReturn”-values
Filter(_specialProduct, CalcReturn <> blank())
Note 1: Filter recognizes “CalcReturn”, whereas CalculateTable does not, and the latter also gives a error when using “calculate ([sum_GrossPTD], Mapping[ID] = 24914)” instead.
Note 2: You might opt to use a measure instead of a calculated table using this filtering, to avoid calculated tables, to speed up the file
Kind regards, Jan vd Wind
thank you @deltaselect , this is used as a measure, showing as table here only for clarity. I appreciate the lineage insight! Good to know the advantages of the Filter function.
