In the table containing your slicer values, you need to add a numeric column with the sort order you want the slicer values to appear in. Then select the column with the slicer values, click on “Sort by Column” in the ribbon and select your numeric sort column.
So I have done this already and when I show the data in the table it works- as it has the row index column in the table or matrix albeit hidden.
However in the bar chart that is bar chart above the row index isn’t used- and in the course I have done (Which has been excellent) This visual isn’t recreated!
I’ve web scraped a simple example akin to your situation. In my example below, the only sort options in the visual are Player and Salary. But, suppose I want to sort the graph by Player Age?
