Filter based on multiple selection - slicerproblem
Hi All,
Background:
I have a dataset that consists of about 200 projects. For each project there are keywords accociated with it. The keywords are split into three different categories (age, datasource and language).
Dataset:
ProjectTitle Keyword - Datasource Keyword - Age Keyword - Language
Test1 Other Adult English
Test1 Other Child English
Test1 Other Adult German
Test1 Other Child German
Test1 Register Adult English
Test1 Register Child English
Test1 Register Adult German
Test1 Register Child German
Test2 Wikipedia Youth English
Test2 Wikipedia Child English
Test2 Register Youth English
Test2 Register Child English
Test2 Wikipedia Youth Italian
Test2 Wikipedia Child Italian
Test2 Register Youth Italian
Test2 Register Child Italian
Desired outcome:
I want to have slicers for each keyword-category (Age, Datasource and Language), and then have a table/matrix that will show the projects that meets the exact criteria of the slicer selections. E.g. I want to be able to select several options from each slicer and only display the projects that meets all the criteria selected.
The problem:
I am able to make a concatenate-measure that I can put in a matrix, but I cant get the matrix to do display what I want it to. E.g. If I select “Child, Youth, and Register”, the matrix should only show the “Test2”-project, however, it shows Test1 as well. I guess the reason for that is that it based on an “OR” statement rather than “AND”. I.e. it checks off for Child or Youth and Register, and not Child AND Youth and Register.
I have a attached a pbix-file that shows a mockup of my real data.
I’ve tried to find solutions to this in various forums but I cant seem to find the answer I need.
Does anyone here have a solution to this (simple?) problem?
Problem.pbix (22.3 KB)
Cheers all.
Hi @Magn,
Thank you for reaching out to the community.
While we wait for other members to share their insights, I’ve taken the liberty of using “Explain Simply,” one of the tools available within Data Mentor (you can explore it here: https://mentor.enterprisedna.co/explain-simply). It generated the following results:.
Feel free to checkout more of our Data Mentor features as you work on your report. These tools are designed to help with tasks like the one you’re working on, and they might accelerate your learning curve.
Cheers,
Enterprise DNA Support Team
