Field Parameters
Is there a way to apply conditional formatting on bar charts while using field parameters. The field parameter consists of multiple measures which is then plotted on a bar chart. The values are in percentage and ranges from negative to positive. I am trying to apply conditional formatting on the bar colours but it’s not working correctly.
Pretty certain this can be achieved.
Do you have a PBIX file you can submit, this will make things a lot easier.
Hi @turner.collier
I noticed you still didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
  • A clear explanation of the problem you are experiencing
  • A mockup of the results you want to achieve
  • Your current work-in-progress PBIX file
  • Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Thank you!
Hello @turner.collier
We notice that no response was received from you on the post above.
We are waiting for your masked demo pbix file and other supporting links and details so other users can help you in your query.
Due to your inactivity, we’ll be tagging this post as Solved.
Should you wish to add your masked demo pbix file and other supporting links and details, you can reopen this thread.
Thank you!
