Hi @Wlknsn,
I might have gone a little overboard… but give this a go:
let fxCom2Tables = ( lTable as table, lKeyColNum as number, rTable as table, rKeyColNum as number, optional Comparison as nullable number ) as table =>
let
BaseTable = Table.Buffer( lTable ),
lKeyColName = Table.ColumnNames( BaseTable ){lKeyColNum},
CompareAs = if Comparison =1 then Comparer.OrdinalIgnoreCase else Comparer.Equals,
AddKeyL = Table.AddColumn( BaseTable, "KeyColCase", each Text.Upper(Text.From( Record.FieldValues(_){lKeyColNum} )), type text ),
AddKeyR = Table.AddColumn( rTable, "KeyColCase", each Text.Upper(Text.From( Record.FieldValues(_){rKeyColNum} )), type text ),
Merge =
if Comparison = 1
then Table.NestedJoin( AddKeyL, {"KeyColCase"}, AddKeyR, {"KeyColCase"}, "Temp", JoinKind.LeftOuter)
else Table.NestedJoin( BaseTable, lKeyColName, rTable, Table.ColumnNames( rTable ){rKeyColNum}, "Temp", JoinKind.LeftOuter),
CompareRecord = Table.AddColumn( Merge, "Compare", each let ToRemoveCols = {lKeyColName} & {"Temp", "KeyColCase"} in
if Table.IsEmpty( _[Temp] ) then List.Repeat( {0}, Record.FieldCount( Record.RemoveFields(_, ToRemoveCols, MissingField.Ignore ))) else
List.Transform(
List.Zip(
Record.FieldValues( Record.ReorderFields( Record.RemoveFields(_, ToRemoveCols, MissingField.Ignore ), Table.ColumnNames(Merge), MissingField.Ignore )),
Record.FieldValues( Record.ReorderFields( Record.RemoveFields(_[Temp]{0}, ToRemoveCols, MissingField.Ignore ), Table.ColumnNames(Merge), MissingField.Ignore ))
), each try if _{0} = _{1} then 1 else 0 otherwise 0
tResult =
Table.SplitColumn(
Table.TransformColumns(
Table.SelectColumns( CompareRecord, {lKeyColName} & {"Compare"} ),
{"Compare", each Text.Combine(List.Transform(_, Text.From), "||"), type text}),
"Compare", Splitter.SplitTextByDelimiter("||", QuoteStyle.Csv), List.Select( List.Difference( Table.ColumnNames(Merge), {"Temp", "KeyColCase"} ), each _ <> lKeyColName ))
in
tResult, Documentation = [
Documentation.Name = "fxCompare2Tables",
Documentation.LongDescription = "Returns 0 for each field value that doesn't match and a 1 for each field value that does match.",
Documentation.Category = "Table",
Documentation.Author = "Melissa de Korte",
Documentation.Examples =
Description = " ",
Code = "How variables should be used. #(lf)
lKeyColNum and rKeyColNum as zero based position of the Key Column #(lf)
optional Comparison as number if set to 1 the case of Key column values will be ignored",
Result = " "
in
Value.ReplaceType( fxCom2Tables, Value.ReplaceMetadata( Value.Type( fxCom2Tables ), Documentation ))
You can optionally disable case sensiivity for key column comparison by entering a 1.
Returns this result when applied to your sample.
However if the tables
always match in both key field value order AND column order. You could use list functions this makes it much more simple and will increase performance…
let fxCompare2Tables = ( lTable as table, lKeyColNum as number, rTable as table, rKeyColNum as number ) as table =>
let
lKeyColName = Table.ColumnNames( lTable ){lKeyColNum},
rKeyColName = Table.ColumnNames( rTable ){rKeyColNum},
tResult =
Table.FromColumns(
{ Table.ToColumns( lTable ){lKeyColNum} } &
List.Transform(
List.Zip(
Table.ToColumns( Table.RemoveColumns( lTable, lKeyColName, MissingField.Ignore )),
Table.ToColumns( Table.RemoveColumns( rTable, rKeyColName, MissingField.Ignore ))
each List.Transform( List.Zip( { _{0}, _{1} } ), (i) => try if i{0} = i{1} then 1 else 0 otherwise 0 )
), { lKeyColName } & Table.ColumnNames( Table.RemoveColumns( lTable, lKeyColName, MissingField.Ignore ))
in
Description = " ",
lKeyColNum and rKeyColNum as zero based position of the Key Column",
Result = " "
in
Value.ReplaceType( fxCompare2Tables, Value.ReplaceMetadata( Value.Type( fxCompare2Tables ), Documentation ))
I hope this is helpful
