I’ve been provided with some data where the address is in a single line. I need to extract the Suburb in a separate column.
I’ve used the text between delimiter function to extract this and in most instances it works, however if the suburb name contains more than 1 word it only shows last word. Would greatly appreciate if there is a solution on being able to extract the full suburb.
In the highlighted row below I need to get New Alexport instead of just Alexport but i’ve hit a roadblock.
Thank you so much for the assitance. I’ve implemented your solution into my code and it works a treat!. In regards to the missing items in the list, I have added in some additional M code to handle these.
