Is there a way to extract the zip code only from an address string with inconsistent formatting? I would like to use the zip code as the geodata so I can show a map of the related customer data by zip code. Here’s an example of my shipping data. In the current format, the data is not recognized as an address format, It only:
Shipping Address
sample company, OK 74501, USA.
123 sample road Dr, Edmond, OK 73034, USA.
456 sample Avenue, Deerfield Beach, FL 33442, USA.
123 sample Highway, Hollsopple, PA 15935, USA.
124 sample Lane, Colleyville, TX 76034, USA.
123345 sample Road, Suite123, Pineville, NC 28134, USA.
Have you tried using the Column From Examples in the Query Editor ( click on Transform Data Tab on Home Tab). I would think as long as each zip code is 5 digits, it will pick it up fine. If you can’t get it to work, upload a sample PBIX file so that we can better assist.
This is exactly how I would have approached it. You also have to trim the data, just to be sure that there are no extra spaces. All Zip Codes will then be consistent and should work.
