Hi friends,
i need some suggestions, actually i have a single query/table which has a field/column according to which i want to seperate and obtain seperate query for as per each field but dynamically. I know i can create a parameter and then create a function to invoke filtered tables. But i need a single M Code/or function which can automatically seperate tables for me instead of invoking function again and again. Please guide. I am sharing excel file for reference as source and i want to seperate tables by depttype column in power query in power bi.
thanks and regards
data.xlsx (8.7 KB)
*** READ FIRST ***
Before you send your question.
Make sure that all details relevant to your question is complete:
- Your current work-in-progress PBIX file - VERY IMPORTANT
- A clear explanation of the problem you are experiencing
- A mockup of the results you want to achieve
- Your underlying data file
Also make sure that your data file contains no confidential information. If it does, click the link above.
*** DELETE THIS MESSAGE IF YOU ARE SURE ALL YOUR DETAILS ARE COMPLETE OR IF THE ABOVE INFORMATION IS NOT APPLICABLE TO YOUR QUESTION.***
