I downloaded the external power tools installer, but the install failed:
Any help is welcome.
Hello and good morning David,
Curious if the installer has been updated, and if the issue has been resolved.
not yet. essentially, I was able to download the EnterpriseDnaInstaller.msi fine. it was the installation itself that failed. the failure happens specifically as “error 1001. Unable to get installer types in the C:\quickmeasurespro.exe assembly. → unable to load one or more of the requested types. retrieve the loaderExceptions property for more information.”
IIRC I thought Brian J created the package way back when. The forum has the history for it with a link to a starter install without the updates. Should be at compatibility of Windows 10
