Export data from All visuals using single click
Hi Team,
A client requested to have a csv export of the data for each visual in the report. The report has many visuals and it updates every day.
I’m looking into a way to single click to export data from all the visuals.
Does anyone know if this is possible in PowerBI, maybe using some DAX Studio or R or Python script?
Regards,
Rommala
Hi @mrommala. DAX Studio can do the underlying tables, but has no knowledge of the visuals. I’m not aware of a “mass-visual-data-export” option. Greg
Hi @mrommala ,
I personally didn’t have that kind of experience and requests. Maybe someone had and can give you better insight.
While you are waiting for the answer, you may check following links (workarounds):
Best regards,
Maja
Hello @mrommala just following up if the response above help you solve your inquiry?
Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’.
