Hi there
With a calculation group in my model I can no longer use implicit measures
The only place I would use them is to bring results into a matrix -
That is I bring in the “First” Result from the results table. In the context of the matrix each student only has a single result so this produces the visual that I want
Now I can’t bring in the result column - because it will not create an implicit measure. Is there an explicit measure that will bring in the first grade. I have tried firstnonblank but that does not seem to work - (I don’t understand what I would put as the “expression” in this context
no implicit measure.pbix (20.9 KB)
