Hello Friends,
I have been trying to convert my “Event_ID” data format to look normal. Unfortunately, I am still struggling. Here is my excel attached. When you look at column “A” some data are showing with this format “2.02E+13”. My goal is to convert the entire column A to have a similar data format. See if you can help or guide me to the right path.
Well, Power Query auto-detects the data type based on the first 1000 rows and therefore, the “Event.Id” is converted into a Whole Number data type i.e., “Int64.Type”. Change this data type to “Text” and you’ll start to see the data as expected. Below is the screenshot of the final results provided for the reference -
