Hello Everyone,
I am facing problem to format number in Euro currency format.
when i select format as currency type it is formatting but it is generating space between Euro symbol and number i want to remove that space.
Hello Everyone,
That’s is accounting format, you need to select Currency.
Hello @NutanPatil
Thank you
Hello @NutanPatil
We’ve noticed that no response was received from you on the post above.
Just following up if the response above help you solve your inquiry.
If it did, please mark his answer as the SOLUTION.
Hi @NutanPatil
Due to inactivity, a response on this post has been tagged as “Solution”.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,.
We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
