Excel BI Power Query Challenge Workout 077
-CAN YOU SOLVE THIS - POWER QUERY CHALLENGE 77-
(Solution in any language also welcome for Power Query Challenges)
Generate the result table from problem table. Quantity in result table is sum of number appearing next to the letter in problem table.
Download Practice File - https://lnkd.in/dQsBbRhr
(Post answers in Comment. Your approach need not be different from others as long as you have worked out your approach independently)
#powerquerychallenge, #daxchallenge, #m, #dax, #powerbi, #powerquery, #powerpivot, #sheets, #googlesheets, #data, #analytics, #businessintelligence, #finance, #excel, #excelchallenge, #python, #r
LinkedIn Post:
LinkedIn Post by:
Alejandra Horvath CPA, CGA
My PQ solution:
let
Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
Split = Table.TransformRows (Source, each
let
x = Text.Replace([String], " ","" ),
y = Splitter.SplitTextByCharacterTransition((a) => not List.Contains({"A".."Z"}, a), {"A".."Z"})(x)
in
y),
ToTbl = Table.FromList(Split, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
Expanded = Table.ExpandListColumn(ToTbl, "Column1"),
SplitByCharTransition = Table.SplitColumn(Expanded, "Column1", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Letters", "Quantity"}),
ChgType = Table.TransformColumnTypes(SplitByCharTransition,{{"Quantity", Int64.Type}}),
Grouped = [Table.Group](http://table.group/)(ChgType, {"Letters"}, {{"Quantity", each List.Sum([Quantity]), type nullable text}}),
Sorted = Table.Sort(Grouped,{{"Letters", Order.Ascending}})
in
Sorted
Cheers :blush:
LinkedIn Post by:
Krzysztof Nowak
My solution in #R
Answer <- data %>%
 mutate(String2 = str_replace_all(String,"(?<=[A-Z])\\s","")) %>% #remove all spaces followed by uppercase letter
 unnest_tokens(input = String2,output = Components,token = "regex",pattern = "\\s",drop = F,to_lower = F) %>% #Split to rows using space as delimiter
 mutate(Letter = str_extract(Components,"[A-Z]"), # extract letters
     Digits = as.numeric(str_extract(Components,"\\d+"))) %>% #extract numbers
 group_by(Letter) %>% #Group by letter
 summarise(Quantity = sum(Digits)) #sum digits
LinkedIn Post by:
Alejandro Simón
Adjunto mi query...
let
  Col = Table.Combine(Table.AddColumn(Source, "Custom", each
    let
    a = Text.Replace([String], " ", ""),
    b = Splitter.SplitTextByCharacterTransition({"0".."9"}, {"A".."Z"})(a),
    c = List.Transform(b, each {Text.ToList(_){0}} & {Text.Combine(List.Skip(Text.ToList(_)))}),
    d = Table.FromRows(c)
    in d)[Custom]),
  Group = Table.Sort(Table.Group(Col, {"Column1"}, {{"Quality", each
let
    a = [Column2],
    b = List.Sum (List.Transform(a, Number.From))
    in b
}}), "Column1"),
  Sol = Table.RenameColumns(Group,{{"Column1", "Letters"}})
in
  Sol
LinkedIn Post by:
Bo Rydobon
M-Code
let
Ans = let z = Text.Combine(Source[String]), a =[List.Select](http://list.select/)(Text.SplitAny(z,"01234568789 "),each _>"") in
Table.Sort([Table.Group](http://table.group/)(Table.FromColumns({a , List.Transform([List.Select](http://list.select/)(Splitter.SplitTextByAnyDelimiter(a)(z),each _>""),Number.From)},{"Letters","Q"}),"Letters",{"Quantity", each List.Sum([Q])}),"Letters")
in
Ans
LinkedIn Post by:
Brian Julius
The rare #powerquery :
100% UI solution
let
  #"Duplicated Column" = Table.DuplicateColumn(Source, "String", "Anchor"),
  RemoveSpaces = Table.ReplaceValue(#"Duplicated Column"," ","",Replacer.ReplaceText,{"String"}),
  #"Split Column by Character Transition" = Table.SplitColumn(RemoveSpaces, "String", Splitter.SplitTextByCharacterTransition({"0".."9"}, (c) => not List.Contains({"0".."9"}, c)), {"String.1", "String.2", "String.3", "String.4", "String.5"}),
  #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Split Column by Character Transition", {"Anchor"}, "Attribute", "Value"),
  #"Split Column by Character Transition1" = Table.SplitColumn(#"Unpivoted Other Columns", "Value", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Letter", "Quantity"}),
  #"Changed Type" = Table.TransformColumnTypes(#"Split Column by Character Transition1",{{"Quantity", Int64.Type}}),
  #"Grouped Rows" = Table.Group(#"Changed Type", {"Letter"}, {{"Sum", each List.Sum([Quantity]), type nullable number}}),
  #"Sorted Rows" = Table.Sort(#"Grouped Rows",{{"Letter", Order.Ascending}})
in
  #"Sorted Rows"
LinkedIn Post by:
Mahmoud Bani Asadi
PQ solution:
let
SplitColumnbyDelimiter = Table.ExpandListColumn(Table.TransformColumns(Source, {{"String", Splitter.SplitTextByCharacterTransition({"0".."9"}, {"A".."Z", " "}), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "String"),
SplitColumnbyCharacterTransition = Table.SplitColumn(SplitColumnbyDelimiter, "String", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Letters", "Quantity"}),
TrimmedText = Table.TransformColumns(SplitColumnbyCharacterTransition,{{"Letters", Text.Trim},{"Quantity", Number.From}}),
GroupedRows = [Table.Group](http://table.group/)(TrimmedText, {"Letters"}, {{"Qty", each List.Sum([Quantity]), type nullable text}}),
SortedRows = Table.Sort(GroupedRows,{{"Letters", Order.Ascending}})
in
SortedRows
LinkedIn Post by:
Eric Laforce
PQ Proposal with following 4 MainSteps
(1) Transform = split by CharacterTransition into Records
(2) Expand Records (3) Group by Letter with Sumof Quantity
(4) Sort
let
Source = Excel.CurrentWorkbook(){[Name="tData77"]}[Content],
Transform = Table.TransformColumns(Source, {"String", each let
_S = Text.Replace(_, " ", ""),
_Split=Splitter.SplitTextByCharacterTransition({"0".."9"}, {"A".."Z"})(_S)
in List.Transform(_Split, each
Record.FromList( Splitter.SplitTextByCharacterTransition( {"A".."Z"},{"0".."9"})(_), {"Letters", "Value"})) }),
Expand = Table.ExpandRecordColumn( Table.ExpandListColumn(Transform, "String"), "String", {"Letters", "Value"}),
ChangeType = Table.TransformColumnTypes(Expand,{{"Value", Int64.Type}}),
Group = [Table.Group](http://table.group/)(ChangeType, {"Letters"}, {{"Quantity", each List.Sum([Value])}}),
Sort = Table.Sort(Group,{{"Letters", Order.Ascending}})
in Sort
LinkedIn Post by:
Taeyong Shin
let
  Source = Excel.CurrentWorkbook(){[ Name = "tblData" ]}[Content],
  ReplaceValue = Table.ReplaceValue ( Source,
    each [String],
    each List.Accumulate ( { "0" .. "9" },
      [String],
      ( a, c ) => Text.Replace ( a, c & " ", c & ", " )
    { "String" }
  Split = Table.ExpandListColumn (
    Table.TransformColumns ( ReplaceValue, { "String", Splitter.SplitTextByDelimiter ( ", " ) } ),
    "String"
  AddCol = Table.AddColumn ( Split, "Letter", each Text.Start ( [String], 1 ), type text ),
  Group = Table.Group ( AddCol, "Letter",
    { "Quantity",
      each List.Sum (
        List.Transform ( [String], each Number.From ( Text.RemoveRange ( _, 0, 1 ) ) )
      Int64.Type
  SortTbl = Table.Sort ( Group, { "Letter", 0 } )
in
  SortTbl
LinkedIn Post by:
Omid Motamedisedeh
let
Custom1 = [A=Source[String],B=List.Combine(List.Transform(A,each Text.Split(Text.Remove(_,{"A".."Z"})," "))),C=List.Combine(List.Transform(A,each Text.Split([Text.Select](http://text.select/)(_,{"A".."Z"," "})," "))),D=Table.TransformColumnTypes(Table.FromColumns({[List.Select](http://list.select/)(C, each _<>""),[List.Select](http://list.select/)(B, each _<>"")},{"Letters","Quantity"}),{{"Quantity", Int64.Type}})][D],
#"Grouped Rows" = [Table.Group](http://table.group/)(Custom1, {"Letters"}, {{"Quantity", each List.Sum([Quantity]), type nullable number}}),
#"Sorted Rows" = Table.Sort(#"Grouped Rows",{{"Letters", Order.Ascending}})
in
#"Sorted Rows"
LinkedIn Post by:
Luan Rodrigues
let
Fonte = Tabela1,
add = Table.AddColumn(Fonte, "lista", each [
a = Text.Replace([String]," ",""),
b = Splitter.SplitTextByCharacterTransition({"0".."9"},{"A".."Z"})(a),
c = List.Combine({b})
][c])[[lista]],
exp = Table.ExpandListColumn(add, "lista"),
div = Table.SplitColumn(exp, "lista", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Letters", "Quantity"}),
gp = [Table.Group](http://table.group/)(div, {"Letters"}, {{"Quantity", each List.Sum(List.Transform([Quantity], Number.From))}}),
res = Table.Sort(gp,{{"Letters", Order.Ascending}})
in
res
LinkedIn Post by:
Victor Wang
let
Split1 = Table.FromValue(Splitter.SplitTextByCharacterTransition({"0".."9"}, {"A".."Z", " "})(Text.Combine(Source[String]))),
Split2 = Table.SplitColumn(Split1, "Value", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Letters", "Quantity"}),
Transform = Table.TransformColumns(Split2, {{"Letters", Text.Trim}, {"Quantity", Number.From}}),
Result = Table.Sort([Table.Group](http://table.group/)(Transform, {"Letters"}, {{"Quantity", each List.Sum([Quantity]), type nullable number}}), "Letters")
in
Result
LinkedIn Post by:
Hussein SATOUR
Thank you Excel BI
 #"Changed Type" = Table.TransformColumnTypes(Source,{{"String", type text}}),
 #"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each Splitter.SplitTextByCharacterTransition(
{"0".."9"}, (c) => not List.Contains({"0".."9"}, c))([String])),
 #"Expanded Custom" = Table.ExpandListColumn(#"Added Custom", "Custom"),
 #"Replaced Value" = Table.ReplaceValue(#"Expanded Custom"," ","",Replacer.ReplaceText,{"Custom"}),
 #"Split Column by Character Transition" = Table.SplitColumn(#"Replaced Value", "Custom", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Letters", "Custom.2"}),
 #"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Character Transition",{{"Custom.2", Int64.Type}}),
 #"Grouped Rows" = Table.Group(#"Changed Type1", {"Letters"}, {{"Quantity", each List.Sum([Custom.2]), type nullable text}}),
in
 #"Sorted Rows"
LinkedIn Post by:
Zoran Milokanović
Generating the result table w/ hashtag#powerquery. hashtag#bitanbit hashtag#powerbi
let
Source = Excel.CurrentWorkbook(){[Name="Input"]}[Content],
ConvertToTable = Table.FromRows(List.Split(List.Accumulate(
Text.ToList(Text.Remove(Text.Combine(Source[String]), " ")), {}, (s, c) => if Value.FromText(List.Last(s)) is number and Value.FromText(c) is number then List.RemoveLastN(s, 1) & {List.Last(s) & c} else s & {c}
), 2), {"Letters", "Quantity"}),
Solution = Table.Sort([Table.Group](http://table.group/)(ConvertToTable, {"Letters"}, {{"Quantity", each List.Sum(List.Transform([Quantity], Number.From))}}), "Letters")
in
Solution
LinkedIn Post by:
Krzysztof Kominiak
let
 AddPos = Table.AddColumn(Source, "Pos", each List.Reverse(List.Skip(List.PositionOfAny(Text.ToList([String]), {"A".."Z"} ,2)))),
 SelCol = Table.AddColumn(AddPos, "Letters", each List.Accumulate( [Pos], [String], (s,c)=> Text.Insert(s, c, "||")))[[Letters]],
 SplitCol = Table.ExpandListColumn(Table.TransformColumns(SelCol, {{"Letters", Splitter.SplitTextByDelimiter("||", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "Letters"),
 RemSpaces = Table.ReplaceValue(SplitCol," ","",Replacer.ReplaceText,{"Letters"}),
 AddNumb = Table.AddColumn(RemSpaces, "Numb", each Number.From(Text.Select([Letters], {"0".."9"} ))),
 SelLetters = Table.TransformColumns(AddNumb, {"Letters", each Text.Remove(_, {"0".."9"} )} ),
 Result = Table.Sort(Table.Group(SelLetters, {"Letters"}, {{"Quantity", each List.Sum([Numb]),type number}}), {"Letters"} )
in
 Result
LinkedIn post by:
JvdV
=LET(x,DROP(REDUCE(0,A2:A5,LAMBDA(a,b,VSTACK(a,LET(c,TEXTSPLIT(b,,CHAR(ROW(65:90)),1),HSTACK(TRIM(TEXTSPLIT(b,,c,1)),--c))))),1),y,TAKE(x,,1),REDUCE({"Letters","Quantity"},SORT(UNIQUE(y)),LAMBDA(e,f,VSTACK(e,HSTACK(f,SUM(IF(y=f,DROP(x,,1))))))))
LinkedIn Post by:
Caroline Blake
=LET(_a,CONCAT(A2:A5),_b,TEXTSPLIT(_a," ",{1,2,3,4,5,6,7,8,9},TRUE),_c,TEXTSPLIT(_a,,_b,TRUE),_d,UNIQUE(_b),_e,MAP(_d,LAMBDA(_d,SUM(_c*(_d=_b)))),VSTACK(HSTACK("Letters","Quantity"),SORT(HSTACK(_d,_e),,1)))
LinkedIn Post by:
Sunny Baggu
2#
=LET(
 _str, TEXTJOIN(" ", , A2:A5),
 _alpha, CHAR(SEQUENCE(26, , CODE("A"))),
 _modstr, REDUCE(_str, _alpha, LAMBDA(a, v, SUBSTITUTE(a, v, v & " "))),
 _tbl, SORT(WRAPROWS(TEXTSPLIT(_modstr, , " ", 1), 2)),
 _qty, MAP(
 UNIQUE(DROP(_tbl, , -1)),
 LAMBDA(a, SUM(--FILTER(DROP(_tbl, , 1), DROP(_tbl, , -1) = a)))
 HSTACK(UNIQUE(DROP(_tbl, , -1)), _qty)
LinkedIn post by:
Daniel Madhadha
let
Source = Excel.CurrentWorkbook(){[Name="Table3"]}[Content],
#"Split Column by Character Transition" = Table.SplitColumn(Source, "String", Splitter.SplitTextByCharacterTransition({"0".."9"}, (c) => not List.Contains({"0".."9"}, c)), {"String.1", "String.2", "String.3", "String.4", "String.5"}),
#"Unpivoted Columns" = Table.UnpivotOtherColumns(#"Split Column by Character Transition", {}, "Attribute", "Value"),
#"Removed Columns" = Table.RemoveColumns(#"Unpivoted Columns",{"Attribute"}),
#"Split Column by Character Transition1" = Table.SplitColumn(#"Removed Columns", "Value", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Value.1", "Value.2"}),
#"Trimmed Text" = Table.TransformColumns(Table.TransformColumnTypes(#"Split Column by Character Transition1", {{"Value.2", type text}}, "en-US"),{{"Value.1", Text.Trim, type text}, {"Value.2", Text.Trim, type text}}),
#"Changed Type" = Table.TransformColumnTypes(#"Trimmed Text",{{"Value.2", type number}}),
#"Grouped Rows" = [Table.Group](http://table.group/)(#"Changed Type", {"Value.1"}, {{"Count", each List.Sum([Value.2]), type nullable number}}),
#"Sorted Rows" = Table.Sort(#"Grouped Rows",{{"Value.1", Order.Ascending}})
in
#"Sorted Rows"
LinkedIn Post by:
Taeyong Shin
=LET(
 txt, REDUCE(A2:A5, SEQUENCE(10) - 1, LAMBDA(a,c, SUBSTITUTE(a, c & " ", c & ", ") )),
 s, SORT(TEXTSPLIT(ARRAYTOTEXT(txt), , ", ")),
 u, UNIQUE(LEFT(s)),
 SCAN( 0, HSTACK(u, u), LAMBDA(a,c,
 IF(ISNUMBER(a), c, SUM(IFERROR(NUMBERVALUE(s, " ", c), )) )
