-CAN YOU SOLVE THIS - POWER QUERY CHALLENGE 33-
(Excel formulas also welcome for Power Query Challenges)
Generate the answer as shown.
If an alphabet appears in A and B both, then alphabet from that column will be listed as per where the frequency is the highest. Hence, A appears in both columns A and B with frequency of 3 and 4. Hence, it gets listed 4 times.
F appears with frequency of 3 in column A but it doesn’t appear in column B, hence F appears 3 times in output.
Download Practice File - https://lnkd.in/dnhddbAc
(Post answers in Comment. Your approach need not be different from others as long as you have worked out your approach independently)
#powerquerychallenge, #daxchallenge, #m, #dax, #powerbi, #powerquery, #powerpivot, #sheets, #googlesheets, #data, #analytics, #businessintelligence, #finance, #excel, #excelchallenge
Excel BI’s LinkedIn Post
