Could you help me find the DAX formula that would allow me to obtain the result for column E?
data Test.xlsx (14.4 KB)
I would like to see the evolution of consumption since 1965.
Thank you
Thank you
@Remi10 ,
Just need to change a context and divide as you want.
You can check formulas under New metrics folder in PBI
Test_1.pbix (23.2 KB)
Hope it helps.
Thank you very much for your help.
