Hello,
I am trying to create a theme on the Theme generator but when I try to import it to my PBI file, It throws an error.
Thanks.
Hello,
Thanks.
Hi @ArgenisRosario ,
You could check number of digits in your color palette.
Similar problem explained in:
Hope it helps.
Good luck.
