I need to send an alert to a list of emails. I used Power Automate to trigger as below:
However, I got error: Flow run failed
Here is my title that set an alert:
Please advise me how to solve this issue?
Thank you very much.
Jennie.
Jennie.
In general Error 429 means you have exceeded the limit of triggers per period (probably 60 seconds according to https://docs.microsoft.com/en-gb/connectors/powerbi/ ). You should find these parameters in Peek code tool.
My suggestion is to check how many alerts for the data tracked you had in Power BI service. Too low limit might be the answer.
You will need to look at the peeks and maximum number of runs within the period of time that a connector can time out. Then adjust the trigger’s timeout settings so that they do not time out.
Please open a support ticket with Microsoft so they can look into what else is throttling your request as they can give you specific insights into each flow run.
Hi @Jennie, did the response provided by @pranamg help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @Jennie, we noticed that no response was received from you with regard to our post last Aug 9th.
We just want to check if you still need further help with this post.
Hi @Jennie, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
