EndOffMonth / Previous Month - Power Query
Good morning,
I need help to write a conditional Statement in Power query.
Basically, I am looking to check if today is the end of the month, and if it is not, I need the date of the previous month.
At the moment, I do not know how to bring the end of the previous month and my If Statement is not working either!
let
Endmonth = Date.EndOfMonth(DateTime.LocalNow()),
Today =  DateTime.LocalNow(),
EndPreviousMonth = "Need Function",
MonthEnd = if #"Today" = #"EndMonth" then #"Today" else "EndPreviousMonth"
in
MonthEnd
Attached is pbix with just this function…
EndOfMonth - Query.pbix (13.0 KB)
This function will be used in a larger script where I need to pass the end of the month date!
Many thanks,
Ezequiel
@ezenunez ,
Try dropping this into a blank query:
let
Today = Date.From( DateTime.LocalNow() ),
LastDayMo = Date.EndOfMonth( Today ),
PrevMo = Date.AddMonths( Today, -1),
LastDayPrevMo = Date.EndOfMonth( PrevMo ),
MonthEnd = if Today = LastDayMo then Today else LastDayPrevMo
in
MonthEnd
That is super great Brian! You make it look so simple!
My next challenge is to add this information in a String that will be used to bring info from an API.
How do you add this to a String? Is this possible or do I need to use a parameter?
By the way, I looking forward to the next Power query course!
Thanks Brian.
Hi @ezenunez
Try this
MonthEndDate=" & Text.From(#“MonthEnd”) & “NumberOfMonthIncluded=6”
I had a few goes but not yet there!
Any other sugestion?
// Find the last end of the month available
MonthEnd = if Today = LastDayMo then Today else LastDayPrevMo,
//Original
data = Json.Document(Web.Contents(ParamApiEndpoint & “/GetGeneralLedgerTrialBalanceReportData?MonthEndDate=2021-10-31&NumberOfMonthIncluded=36”,
// Test 1 data = Json.Document(Web.Contents(ParamApiEndpoint & “/GetGeneralLedgerTrialBalanceReportData?MonthEndDate=&Text.From(MonthEnd)&NumberOfMonthIncluded=36”,
// Test 2 data = Json.Document(Web.Contents(ParamApiEndpoint & “/GetGeneralLedgerTrialBalanceReportData?MonthEndDate=&Text.From(#“MonthEnd”)&NumberOfMonthIncluded=36”,
// Test 3 data = Json.Document(Web.Contents(ParamApiEndpoint & “/GetGeneralLedgerTrialBalanceReportData?MonthEndDate=&“Text.From(#“MonthEnd”)” &NumberOfMonthIncluded=36”,
Hi @ezenunez,
In your original code snippet your date is formatted as yyyy-mm-dd
This #“MonthEnd” query will return a string in that format
let
    Today = Date.From( DateTime.FixedLocalNow() ),
    MonthEnd = if Today = Date.EndOfMonth( Today ) then Today else Date.EndOfMonth( Date.AddMonths( Today, -1)),
    DateString = Text.Combine( List.Reverse( Text.SplitAny( Text.From( MonthEnd ), "-/" )), "-")
in
    DateString
Incorporating that code, will look something like:
data = Json.Document(Web.Contents(ParamApiEndpoint & “/GetGeneralLedgerTrialBalanceReportData?MonthEndDate="&#“MonthEnd”&"NumberOfMonthIncluded=36”,
I hope this is helpful
Hi @ezenunez
you’ve to pass date in this format only
Change the date format
FinalDate = Text.From(Date.Year(MonthEnd))&"-"&Text.From(Date.Month(MonthEnd))&"-"&Text.From(Date.Day(MonthEnd))
Replace original code
MonthEndDate=" &FinalDate& “&NumberOfMonthIncluded=36”
End solution:
Code from Melisa where return an String
Added to the string by inserting the result &" xxx"&
Thank you!
good job @Melissa …should have got the solution marked for it :slight_smile:
