Power Bi embedded help us to integrate our power bi report on any platform to showcase our report .Behind the curtain it uses the power bi web services only .So you have setup incremental on power bi web then you do not need to setup anything extra.
Hello @ezenunez , good to see you are having progress with your inquiry.
Did the response from @Anurag help you solve your inquiry? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
