Hi all,
I have noticed this past month that the embedded code I create from PBI Service through the "Publish to web " option do not work. To be more precise if I try for example early in the morning the reports render fine but after 9 or 10 in the morning I get a message that says “content is not available”.
On the other hand the links created through the “Secure Embed Option” render fine all day long.
I am located in Greece … I dont know if it has to do with the tenant servicing Greece.
The same issue I face when I try to access content from sites that showcase PBI reports (I guess created with Publish to web option).
By searching the web I havent got a clear understanding if urls that were generated with “Publish to web” option are qeued so during high traffic hours time out.
Does anybody else has the same problem?
Thanks in advance
George
