I know I can embed a full report page from PowerBi into PowerPoint with the “share link”. However, is there a way to only embed a single visual from the report page?
From the image below, i only want to embed the single chart in the top right hand corner. Can i do that?
You can create a Bookmark for Line chart and full report and click on Line button when you want to export only line chart and Full button when you bring back all the visuals so that you don’t have to create it again.
Hi Dharma,
I’m not sure you fully understood my ask.
I’m embedding PowerBi into PowerPoint using the link provided in the PowerBi Service. However, when the embedded link is created it reflects the full page on the report. I want it to only represent a single visual. Is there a way to get a link for a single visual? Does that make sense?
There is a way but the single chart can only be seen as saved image. Basically you click to see the chart in full view and then in PPT click on Show as saved image.
