Been a while since i’ve been here, but i’m a little bit stuck and need a fresh perspective.
I’m creating a report where the user can select a time period and i want a chart to group people into categories of hours worked, theres 1000’s of people. ie, Low, Medium & High. Obviously you cannot precalculate this as you do not know the exact time period the user will select, it might be 1 week or 6 months.
I can easily calculate the median and work out the category each person should be in as a measure, but not sure how to get this into a chart. I feel like i’m missing something super obvious.
I’ve googled Dynamic X Axis and Power BI is not capable of that as yet, is there a visual that can?
Thanks, I’m using analysis services so thats no use to me. I ended up pre-calculating a std devision score in the database, and only allowing the user to pick 1 month period, i did get the chart to work in the above example, but it didn’t look that good imo, instead of the XAxis i dropped the Pricing Group into the legend and the chart sucks a bit… too narrow etc.
