I have a DAX measure called Age that shows an Employees Age based on the selection value of the Year
I then wanted to create a Calculated Column to create an Age Banding based on the Measure Age
so I created the Calculated Column called Age Range but every value returning is showing -20.
I was then told to look at Dynamic Segmentation.
So based on this I created a new measure called Age 2 which in results lets me include the column Age Band that holds the Ranges I require.
The problem is when I select Year 2021 the Employment Id Emp06 is missing, when I select Year 2022 then the Employment Id Emp13 goes missing. The other years 2019 and 2020 shows all the Employees.
Any ideas what is going on? I think it has something to do with those Employment Id that go missing go into a different Age Band
Dynamic Calculate Age at point of time date selection v2.pbix (158.5 KB)
