I have a report layout that lists the day of the month in each column and then the last 3-month average.
However, the days are dynamic, so when it’s the current month, they only want to see that number of days reflected in the report.
I am not sure how to do this within Power BI. If I create a column for each day of the month, that would solve part of my issue, however, it’s not dynamic.
May I see a picture of a dummy report? That way I can help you in a more effective way.
From what you are stating, probably the best course is to transform the report to a better form using the Query Editor, but I can’t affirm that until I see the report structure.
Please note, this is built on an aggregation table where the underlying table contains about 40M. The aggregation table contains 4M. I have to have the ability to switch between months & years and this be dynamic.
