Hello @kkrj.ankit,
Thank You for posting your query onto the  Forum.
Well, is this the type of result that you’re looking for? Below is the screenshot provided for the reference -
In the above post, as you’ve suggested -
“If I select “Nature of Business” under dynamic x-axis and “bus_type” under filters then the user should be able to see a single bar of that selection.” - So I’ve highlighted those selections and achieved the results.
Now, in order to achieve this, I’d to make just a small change in the formula and i.e. here’s the original formula that you’ve written for the “Total Leads#” as mentioned below -
Total Leads# =
IF( ISBLANK( DISTINCTCOUNT ( Loan_Data[code] ) ) , 0 , DISTINCTCOUNT ( Loan_Data[code] ) )
Now, since it includes a “0” in your formula, it showed the chart which were equal to 0 as well. I’ve just replaced the “0” with the “BLANK()” and below is the formula provided for the reference -
Total Leads# =
IF( ISBLANK( DISTINCTCOUNT ( Loan_Data[code] ) ) , BLANK() , DISTINCTCOUNT ( Loan_Data[code] ) )
Also you can write the formula as follows, if you still want to include 0 but want to show greater than 0 results. Below is the formula provided for the reference -
Total Leads# =
VAR TotalLeads =
    0 ,
IF( TotalLeads <= 0 ,
    BLANK() ,
    TotalLeads )
I’m also attaching the working of the PBIX file for the reference.
Thanks and Warm Regards,
Harsh
Data Analysis.pbix (1.0 MB)
