I need to display data in a table visual. Rows that may look as duplicates are only displayed once. In the image below there should be two records for Labor Hours 0.50.
Once I add a unique value to the table such as a primary key then the second 0.50 entry is displayed.
The Engineer column comes from a different table and therefore cannot be used to create a uniqueness.
What would be the best way to have all data display without adding the primary key?
In the left column you can perhaps go to Model and if you have multiple tables you could do a join where you have unique identifiers to return data that matches. Also make sure you aren’t using the Distinct function.
@NadimG Create a new column for the same column and concatenate Zero Width character:
Zero Width Col =
VAR TargetCol = Table[Column]
VAR TargetColLen = LEN ( Table[PrimaryKey] )
-- ^ If not PRIMARY KEY then a create a combination of other cols like
-- LEN () + LEN ()
TargetCol
& REPT (
UNICHAR ( 8204 ),
TargetColLen
Hi @NadimG, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread
