Hello @Reporting,
Drill-through shows the chunck of the data points of a particular category or set of categories based on the temporary filters applied, if any, onto a source page. That is, temporary filters which are applied in the form of slicers are carried forward to drill-through as well. In your case, you’ve applied a fixed filter under the FILTER PANE as a condition where “Product Category = Business”. So by default, onto a drill-through page, it’ll always show the results for Business only.
If you want drill-through page to showcase all the categories except “Business” then you need to apply the filter in the form of slicers. Below are the steps provided to achieve the results -
1). Remove “Product Category” field from the Filter Pane and convert it in the form of slicers. So now, if you select “Business” as a option, you’ll still see the same results onto the first page as you were
seeing it previously.
2). On the second page, add all the required fields under the drill-through section.
3). Disable the option of “Keep all filters” under the drill-through page. That’s because, by doing so, the filters which’re applied in the form of slicers will not be carry-forwarded to the drill-through page.
4). So now, when you right-click and apply a drill-through, you’ll see results for all the Product Categories including “Business”. But since we want to evaluate the results for all the categories except Business. Here’s the final step.
5). Now apply a fixed filter i.e., under the FILTER PANE of the drill-through page select all the categories except Business.
And now, when you apply the drill-through, you’ll see all the results except Business as a category.
Thanks and Warm Regards,
Harsh
Drill Through - Exclude Filter.pbix (1.3 MB)
