If in a dashboard, there are 3 bar charts, with the same hierarchy for the x-axis, Is it possible that drilling down on one automatically drills down on the other?
I am aware that if I select one specific bar on one of these does reflect a change on others, however, my question relates to drill up and drill down arrows.
So for example all have a hierarchy of Country, State & City. Is it possible to click on drill-down arrow to go down from country to state in one bar chart, and have other bar charts automatically drilled down to state aswell. and same for gowing further down next level
Hi @jps, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster.
