Hi all,
I recently started a new Data Analyst job at a company, and whenever I try to download one of their datasets, it’s take forever. I was wondering if this was normal? They use PBI Premium and the dataset I’m trying to download is 1.5GB.
Hi all,
Hi ,
1.5GB of report will take time to download i experience the same with file size around 600MB .
Hi @Everett
Due to inactivity, we’d like to conclude that your inquiry was out of the experts’ and users’ bounds.
If you were sure you provided all pertinent context to your concerns and read how to use the forum more effectively and still find your question unanswered, your membership also comes with relevant resources that may help you with your Power BI education, so we advise that you check these resources as well.
Yes it’s just too big in my opinion. My quick recommendations is to break apart the model in small pieces. You likely don’t need everything in the one model for what you want to analyze
