Divide/Calc Function
I would like to divide the Sales Volume data from the top Matrix chart with the bottom Matrix chart to get Volume share etc on page 3. See pbixhttps://drive.google.com/file/d/186vsjbqclSXB4m5LGwdp3agMQ6-63LDs/view?usp=sharing
Hi @Yrstruly
Please give a try with below DAX if it works on your actual data as the sample data is not enough to visualize it.
BottomMatrix = SUM( Sheet1[Sum of Sales Volume] )
TopByBottom =
    [BottomMatrix] ,
    USERELATIONSHIP( Sheet1[Brand], Sheet3[Brand] )
Mukesh
Hi @Yrstruly, did the response provided by @MK3010 help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @Yrstruly, we’ve noticed that no response has been received from you since the 11th of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Yrstruly, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks.
Itdoes not work.
