Disable other options during right click while drilling through a bar chart?
Is there a way to disable other options during the right click while drilling through a bar chart ? See below.
I want to only keep drill through menu option. But hide or disable the rest (yellowed)
Thanks!
All I can find on the subject is in regard to Power BI Embedded, nothing on how to do this in the Service.
If you wouldn’t want any Options or Context Menu’s to be available, there would be an easy work around, just place a fully transparant object over your visuals and your done.
Anyway this is what I’ve found for you:
Super clever – I’m going to file that one away for future use…:grinning:
Thanks Melissa for your info. this is very helpful
