Currently, I am exploring the option of using Direct Query instead of the Import option to assess the performance of the model. I am querying a table with 20m rows. For simplicity, let’s assume that the data in the table is tidy and it’s in a good shape, so there is no need to apply transformation (I wish ). I noticed when I try to create a measure (Using SWITCH function in my case) I couldn’t reference the column header? Any ideas as to why I can’t?
What I’ve found when I’ve had functions not working correctly is that I was trying to create the measure against the wrong table. Could that be what you’re doing here?
I agree with you, as I have fallen into that trap before. But what if I am querying only one table, I wouldn’t expect this to happen, right?
To bring this to life, I am attaching a sample PBIX file, which connects to AdventureWorksDW2014.DimProductCategory only. The table contains five columns, as seen below:
**** Update ****
Interestingly, when I add a calculated column, the column headers show! This means, it will work with calculated columns only? But, I don’t wish to add more data, I would like to use measure.
I’ve done some searching for more concrete answers and what I’ve found is that with SWITCH in a measure, you have to use the fully qualified column name (‘Table’ [Column]) and you also have to be using an aggregator (Min, Max, Sum).
Another option might be to edit the query to make the changes as you bring in the data?
