I have been working through the module for multi measure dynamics and have come across a problem. I have two slicers working from switch statements and have combined them. One selects dollars or units and the other selects viewing the outcome as a percentage or an actual value.
It is the second switch I am having trouble with - I can only format to see the result as either numbers OR % - I do not see how to say ‘in situation A show me the number, in situation B convert it into a %’
The statement I am using is:
Fcst vs Budget. =
SWITCH( TRUE(),
[Metric Selected 2] = "Actuals", [Fcst Vs Budget],
[Metric Selected 2] = "%", [Fcst Vs Budget %],
[Fcst Vs Budget] )
Is there a way to ensure that when % is selected the format is also %?
Thank you - it is frustrating after hours of working to get the switches to work but if I can do it within the measure that should be ok - how do I add the recommendation you made within the context of my formula above - I cant get it to work?
