I’ve been able to join a date column to a date table where numeric values of Month and Year exist, and the comparable DAX measure logic I’m using will work. However, I’d like to get the “_MonthlyRevenue” measure to work using the fact table “period start date” value.
In the attached sample csv source file and pbix, the ATD_RVNU column reflects a cumulative total [for the project & group] by period start date (i.e. first date of each month). I’m looking to work backwards from the running sum total value by period start date, and derive a monthly revenue column (a.k.a. “_MonthlyRevenue”).
Is there DAX which would produce the monthly revenue amount without joining a date table?
Please modify/share the DAX measure logic which does the trick.
The first thing i notice in your provided PBIX that your PROJ_NBR(project number) in table is aggregated because it is numeric if i interpret it right then it should not be agg so i remove that agg and done the below changes in your existing DAX:
_MonthlyRevenue =
VAR MonthCurrent = month(SELECTEDVALUE(‘Cumulative Revenue’[Period Start Date]))
VAR YearCurrent = year(SELECTEDVALUE(‘Cumulative Revenue’[Period Start Date]))
VAR proj=SELECTEDVALUE(‘Cumulative Revenue’[PROJ_NBR])
