Hi all. Sorry for the ask, but I’m between a rock and a hard place with a deployment and have an imminent deadline.
A Power BI infrastructure was designed and setup by another (now replaced by me) consultant and consists of separate DEV, TEST, and PROD environments, each consisting of:
1 SharePoint folder containing multiple Excel files as data sources
3 Power BI Workspaces, 1 each for Dataflows, Datasets, and Reports (each with different access control lists)
I’ve been asked to make recommendations later today on the use of deployment pipelines to move the code between environments, and, as it’s my first-time using deployment pipelines, I setup a quick test that seemed to suggest a single workspace per environment may be preferred by the corporate IT resources who will be doing the deployment (i.e., less work for them). So I wanted to ask the forum members a quick question:
should I keep 3 separate workspaces per environment, OR
should I have 1 workspace per environment (containing 2 dataflows, 1 dataset, and 2 reports)
Which do you think is best? Any other thoughts would also be greatly appreciated.
In case of using a workspace per environment, we would have only 3 workspaces:
WS_DEV
WS_TEST
WS_PROD
And a single Pipeline:
Pipeline: WS_DEV, WS_TEST, WS_PROD
I think that the configuration of the workspaces should be done based on the audience to which the content of each of them is directed.
I was reading the following article in case it can help you.
Thanks @jafernandezpuga for the thought/links. Yes there are 9 workspaces now (3 per environment) so there will be 3 deployment pipelines to setup.
Thanks @EnterpriseDNA … while @jafernandezpuga’s comments are more than a direction, the client couldn’t define the reporting audiences (“just give us the report”), so we chose as simple a workspace layout as possible and are using 1 per environment, so 3 in total. Regardless, Jose’s answer helped and has been marked as the solution. Thanks, Greg
