I created a (“Point” or scatter Plot) report using “Deneb” in Power BI, but having an issue with the “Y-axis” as some of the String Names are too long (The Chart is cutting them off) and not allowing me to extend. Is there an easy way to extend or override the default String limitation to names in the Y-Axis (in Specification or Config)?
Please see file for Example. Basically project names are little longer than what seems to be default, not sure if i have a code that is limiting them or a code I can input to extend the name.
