Need some help on adding a “Text Mark” based on conditions in a field (not specified in X or Y axis).
If Field “Extra” = “Added”, would like to have an “A” in both QuarterOne and QuarterTwo circles. If Field “Extra” = “Deleted”, would like to have “D” in each of the circles. I was not sure if can designate off string or needs to be Quantitative to do text conditions. Test File.pbix (1.5 MB)
Had another one with same file. If I add gridlines to the below visual and I use the “tickBand”: “extent” encoding, can I close off the grids where the title is? Would like to add a line (red line), but not sure it this is possible since these are the tick hashmarks. If this isn’t possible, any workarounds (i.e. moving title within box)? Test File.pbix (1.5 MB)
Please do not ask new questions on solved threads. Rather, create a new thread and link to an existing solved thread if applicable.
@EnterpriseDNA , please split this new question into its own thread starting with the above post.
Regardless, I’m sure there are a number of better ways to accomplish what you want, but I’m under severe time restrictions today, so here’s a quick-and-dirty solution.
change Y axis to ordinal
add 5th mark of type “rule” and hard-code values for X, Y, and Y2
add a “labelPadding” key:value pair to the Y axis to indent the “Title” field
