Why is the bar chart only sorted if I use the “op”: “sum” property?
why should we use the OP to sort, what does this property actually do?
Hi @domingo42. The default sort for a type = nominal field will be alphabetic by the field name [in your case, country]). If you want to use a sorting based on a different field, then the sort block can be added (in your case using the sum operation in descending order on the Total Sales field).
Hope this helps.
Perfect explanation Greg, thank you very much, now I understand this property OP
