[Deneb Question] Error when using highlight function
Hi. I’m trying to make a highlight on hover effect on my line chart, but I’m getting the following error:
I did some googling, looked at Vega Lite’s documention, looked at @Greg workout, but I still did not find where I should put the param definitions in order to remove the duplicate error. I know if I use the code example from the the documentation I will get it to work, but I wanna learn how to put it on my own, so I have more freedom and in the future can implement it on already made visuals, shaping it as I wish.
Thank you.
FatMasked.pbix (3.4 MB)
Code
“data”: {“name”: “dataset”},
“params”: [
“name”: “highlight”,
“select”: {
“type”: “point”,
“on”: “mouseover”,
“encodings”: [“x”, “y”]
“name”: “select”,
“select”: “point”
“encoding”: {
“color”: {
“condition”: {
“param”: “highlight”,
“field”: “Regiao”,
“type”: “nominal”,
“legend”: null
“value”: “grey”
“opacity”: {
“condition”: {
“value”: 1
“value”: 0.2
“layer”: [
“mark”: “line”,
“encoding”: {
“x”: {
“field”: “Dia Mes”,
“type”: “nominal”,
“title”: “date”
“y”: {
“field”: “Faturamento”,
“type”: “quantitative”,
“title”: “Faturamento”
“encoding”: {
“x”: {
“aggregate”: “max”,
“field”: “Dia Mes”,
“type”: “nominal”
“y”: {
“aggregate”: {
“argmax”: “Dia Mes”
“layer”: [
{“mark”: {“type”: “circle”}},
“mark”: {
“type”: “text”,
“align”: “left”,
“dx”: 4
“encoding”: {
“text”: {
“field”: “Regiao”,
“type”: “nominal”
“config”: {“view”: {“stroke”: null}}
Hi Claudio. As always, please upload the work-in-progress PBIX file to help the forum members review your issue.
Hi, Greg.
Uploaded the pbix file on the main post.
Thanks,
Claudio
Hi Claudio.
I think this may be a data issue, where there are 3 values for “Regiao” (PE, SC, SP), with each being assigned a “highlight” name by Vega-Lite (and its subsequent confusion, hence “tuple”). I took a quick look online and there doesn’t seem to be alot about this error (at least that I could find).
Not sure what else to suggest, except perhaps to remove all highlighting and get the chart to look exactly as you want it, then work on a copy adding the highlight parameter and conditions one-at-a-time and hopefully see where the error surfaces.
Just as a general note, please format all code added to your posts (unformatted code is very difficult to read and required cut-and-paste into another tool that has formatting before it can be properly reviewed).
_eDNA Forum - Format DAX or PQ
Ok, Greg. Thank you.
I will try to remember formating the code on next times.
What I found out about the error is that params definition should not be on top priority, but I don’t know where it should be in the middle of the code. When I just copy/paste the one on the documentation and replace with my data, it works perfectly.
Regards,
Claudio
