Hi @nithesh.n15
The original thread has not yet been split and a new thread has not yet been created, so I’m creating a new thread and linking to the original thread.
Q (as it was added to original solved thread):
Is it possible to change the distribution chart like Normal distribution’s mean to be as IMDB Rating’s mean as default and not to allow user’s to modify the mean. Currently here user can change the mean of Normal distribution.
A:
Yes.
The statistics were added to the Power BI dataset instead of calculating them directly in Deneb/Vega-Lite. Two new measures were added:
Mean = CALCULATE(
AVERAGE( Movies[IMDB Rating] ),
REMOVEFILTERS( Movies)
Standard Deviation = CALCULATE(
STDEV.P( Movies[IMDB Rating] ),
REMOVEFILTERS( Movies )
Then in Deneb/Vega-Lite, 2 “lookup” transforms were added to add the [Mean] and [Standard Deviation] fields to the [Sequence] dataset. Finally, the [densityNormal] calculation was revised to use the [Mean] and [Standard Deviation] from the dataset.
(The proper calculation of the value [_y_factor] for the normal distribution is left for further development; I used a value of 1000 in this example.)
Hope it helps.
eDNA Forum - Deneb Distributions - V1.pbix (1.5 MB)
