Hello, I hope you are well,
On the X axis, I have the measure Sales, which ends in 10,000,000, but according to the filters performed on the dashboard, this final value becomes dynamic.
How can I make this final value at 10,000,000 stay fixed?, that is, it does not change according to the filters performed
This was the simple code I used so far
I already tried to use
“scale”: {“domain”: [0,10000000] }
but was not successful
March 16, 2023, 6:58pm
2
Can you please upload your PBIX?
Example.pbix (1.5 MB)
Hello Greg, because it contains confidential data, I attached another Pbix but the logic is the same.
March 17, 2023, 10:49am
4
Hi @domingo42 .
Your syntax was correct, but you maximum value was wrong: once this was changed to 10 billion, it worked.
Here’s the full Vega-Lite code:
"data": {"name": "dataset"},
"encoding": {
"y": {
"field": "Country (Short)",
"type": "nominal",
"sort": "-x"
"x": {
"type": "quantitative",
"field": "$ Sales",
"scale": {
"domain": [0, 1000000000]
"mark": {
"type": "bar",
"tooltip": true
Hope this helps.
eDNA Forum - Fix X-axis.pbix (1.5 MB)
Thank you so much Greg for your help as always
