One of the interactivity features built-in to the Vega-Lite language and enabled in Power BI by the Deneb custom visual is panning and zooming. Here’s an example of a simple sales by country by month bubble chart:
This can easily be added to any visual by binding an interval selection parameter to the scales (aka axes) with a small code block:
"params": [
"name": "_pan_and_zoom",
"select": "interval",
"bind": "scales"
Once implemented, you can pan by clicking-and-dragging with the mouse, and you can zoom by holding-down the CTRL key and rolling the mouse wheel. Note that the axes adjust automatically when panning or zooming.
This example uses a number of optional Deneb/Vega-Lite components, including:
- a title block c/w subtitle
- a circle mark with:
- partial transparency (opacity)
- black outline (stroke)
- Power BI theme colours (fill)
- a custom tooltip with country, month, year, and sales (month, year, and sales using standard Power BI format strings)
The intent of this exercise is not to provide a complete solution for finished visuals, but rather to serve as a starting point for further custom visual development.
Also included is a sample PBIX using the Enterprise DNA Practice Dataset as a demo.
NOTE: This exercise is provided as-is for information purposes only, and its use is solely at the discretion of the end user; no responsibility is assumed by the author.
Deneb Examples - Pan and Zoom.pbix (1.7 MB)
