Deneb Example - Waterfall Chart
Deneb/Vega-Lite can be used to display a series of bars and labels thus creating a waterfall chart. The period-based example herein consists of 3 parts: a “begin” column, twelve period (monthly) increase or decrease ranged columns, and an “end” column. The data used is a simple sample Sales dataset (the Enterprise DNA Practice Dataset), with a disconnected years table, a couple of simple report filters to reduce the data, and three DAX measures added to ease the analysis.
This example illustrates a number of Deneb/Vega-Lite features, including:
0 - General:
  • use of a “transform” block to extend the dataset with an in-visual calculations for previous month amount, amount and percent variance, and labels
  • use of a “params” block to enhance the dataset with variables for the column colours
    • out colour: Power BI theme colour = Divergent/Min
    • positive colour: Power BI theme colour = Sentiment/Positive
    • negative colour: Power BI theme colour = Sentiment/Negative
  • use of an “layer” block consisting of 6 sections: 3x bar (before year, in-year, after year), 3x text (out-year, in-year positive, in-year negative)
1 - Before Period:
  • use of a “transform” block to filter the dataset (month number = 0)
  • use of a “bar” mark with 60% opacity and the “out” colour parameter
  • use of a Y-axis with approximately 10 ticks
2 - Period:
  • use of a “bar” mark with 60% opacity ranged from period minimum to period maximum
  • use of conditional colour (if variance < 0 then “negative” colour parameter else “positive” colour parameter)
3 - After Period:
  • use of a “transform” block to filter the dataset (month number = 13)
4 - Outside Period Labels:
  • use of a “transform” block to filter the dataset (month number = 0 or 13)
  • use of a “text” mark using Vega-Lite’s formatting for SI units and 4 significant digits
5 - Inside Period Labels (Positive):
  • use of a “transform” block to filter the dataset (variance >= 0 and 1 <= month number <= 12)
  • use of a “text” mark with line-break character to display both the signed amount variance (using Vega-Lite’s formatting for SI units and 2 significant digits) and signed percent variance (using Vega-Lite’s formatting for percent and 1 decimal place)
  • Y position set to above period maximum
6 - Inside Period Labels (Negative):
  • use of a “transform” block to filter the dataset (variance < 0 and 1 <= month number <= 12)
  • Y position set to below period minimum
DAX Measures:
Amount =
VAR _DisconnectedYear = SELECTEDVALUE( Years[Disconnected Year] )
VAR _Year = SELECTEDVALUE( Dates[Year] )
VAR _Month = SELECTEDVALUE( Dates[Month] )
VAR _BeforeYear =
CALCULATE( [Total Sales],
FILTER( Dates,
Dates[Year] = ( _DisconnectedYear - 1 ) && Dates[Month] = 12 ) )
VAR _InYear =
FILTER( Dates,
Dates[Year] = _DisconnectedYear ) )
VAR _AfterYear =
FILTER( ALL( Dates ),
Dates[Year] = _DisconnectedYear && Dates[Month] = 12 ) )
VAR _Result = SWITCH( TRUE(),
MAX( Dates[Year] ) = ( _DisconnectedYear - 1 ) && MAX( Dates[Month] ) = 12, _BeforeYear,
MAX( Dates[Year] ) = _DisconnectedYear, _InYear,
MAX( Dates[Year] ) = ( _DisconnectedYear + 1 ) && MAX( Dates[Month] ) = 1, _AfterYear,
BLANK()
_Result
Month Name =
MAX( Dates[Year] ) = _DisconnectedYear - 1 && MAX( Dates[Month] ) = 12, “BEGIN”,
MAX( Dates[Year] ) = _DisconnectedYear, MAX( Dates[Month Short] ),
MAX( Dates[Year] ) = _DisconnectedYear + 1 && MAX( Dates[Month] ) = 1, “END”,
BLANK()
_Result
Month Number =
MAX( Dates[Year] ) = _DisconnectedYear - 1 && MAX( Dates[Month] ) = 12, 0,
MAX( Dates[Year] ) = _DisconnectedYear, _Month,
MAX( Dates[Year] ) = _DisconnectedYear + 1 && MAX( Dates[Month] ) = 1, 13,
BLANK()
_Result
The intent of this example is not to provide a finished visual, but rather to serve as a starting point for further custom visual development.
This example is provided as-is for information purposes only, and its use is solely at the discretion of the end user; no responsibility is assumed by the author.
Deneb Examples - Waterfall Chart.pbix (1.7 MB)
marking as solved
That’s amazing! Great work. Do you have a stacked version of a waterfall chart? I am new to Deneb so I can’t even tell how hard it would be to implement stacked option. I would be grateful for any feedback
Hi @bartus2409200121.
It is discouraged to make a new post on a solved thread. Please start a new thread and link to an existing forum post if it help explain your issue.
_eDNA Forum - Link to existing post
To help us further analyze your current state and visualize your issue, could you please provide as many as you can of:
  • Your work-in-progress PBIX file, using sanitized data if necessary
  • Your dataset as an Excel file (again, sanitized if necessary)
  • A detailed mock-up (marked-up screenshot of the visual in question or Excel or PowerPoint file) showing your desired outcome.
Also, if you provide DAX, Power Query, or Deneb JSON code in your post, please format it using the built-in formatter.
_eDNA Forum - Format DAX or PQ
