Deneb/Vega-Lite can be used to generate a Financial Waterfall, which graphically depicts the major elements of a profit and loss statement.
(Perhaps its just the engineer in me, but I’ve always found P&L statements difficult to read and wanted to see if Deneb could help make the comparisons more visible.)
The example presented herein uses a ranged column chart and data label arrays to increase the utility of the visual. A simple year slicer is included, and a percent toggle (gross revenue; previous statistic) is included to provide interactivity.
As this was primarily a Deneb investigation, and as I have minimal financial experience, minimal time was spent sourcing a representative dataset, and in the end a simple dataset representing some common P&L categories was synthesized.
This example illustrates a number of Deneb/Vega-Lite features, including:
0 - General:
- a “title” block with subtitle
- a shared “params” block with:
- radio buttons (gross revenue; previous statistic) to select the percent target
- a shared “transform” block with:
- a “calculate” transform to compose an expanded item identifier (id, type, delimited name) to ease sorting and to make the id, type, and delimited name available for axis processing
- a “calculate” transform to determine the signed increment amount
- a “window/sum” transform to determine the cumulative amount for the range top amount
- a “calculate” transform to determine the range bottom amount (statistic = 0)
- 5x “calculate” transforms and 5x “joinaggregate/sum” transforms to determine the statistic amounts
- 3x “calculate” transforms to determine the percentages
- 3x “calculate” transforms to format and compose the data label array
- a “vconcat” block for the custom legend and column chart
1 - Legend:
- a 3-record in-line dataset (income, expense, statistic)
- an “arc” mark of zero size to leverage the legend functionality built-in to Vega-Lite
- a “color” encoding with:
- a hard-coded scale (domain and range) for the colours
- conditional label font size, weight, and position and conditional symbol size (statistic larger and bold)
2 - Waterfall:
- a shared “encoding” block to ensure all marks use the same X and Y axes and colours
- the X axis configured with:
- multi-line labels for the items (split into an array using the delimiter)
- conditional font size (statistic larger)
- conditional font weight (statistic bold)
- the Y axis configured with:
- both a Y (top) and Y2 (bottom) to create an amount range
- a “layer” block with:
- a “bar” mark for the columns with conditional colour
- a “text” mark for the amount/percent labels with:
- conditional font size, weight, and colour (statistic larger, bold, white)
- conditional label position (income above, expense and statistic below)
Deneb/Vega-Lite JSON Code:
"title": {
"anchor": "start",
"align": "left",
"offset": 20,
"text": "Power BI Financial Waterfall using Deneb",
"font": "Verdana",
"fontSize": 24,
"fontWeight": "bold",
"fontStyle": "normal",
"subtitle": "Data Source: synthetic data",
"subtitleFont": "Verdana",
"subtitleFontSize": 16,
"subtitleFontWeight": "normal",
"subtitleFontStyle": "italic"
"data": {
"name": "dataset"
"params": [
"name": "_percent_target",
"value": "of Gross Revenue",
"bind": {
"input": "radio",
"options": [
"of Gross Revenue",
"of Previous Statistic"
"name": "Percent: "
"transform": [
"calculate": "pad( datum['ID'], 2, '0', 'left' ) + '-' + slice( datum['Type'], 0, 1 ) + '-' + datum['Item with Delimiter']",
"as": "_item_id_type_name"
"calculate": "datum['Type'] == 'Income' ? datum['Amount'] : datum['Type'] == 'Expense' ? -1 * datum['Amount'] : 0",
"as": "_increment_amount"
"window": [
"op": "sum",
"field": "_increment_amount",
"as": "_top_amount"
"sort": [
"field": "ID",
"order": "ascending"
"frame": [
null,
0
"calculate": "datum['Type'] == 'Statistic' ? 0 : datum['_top_amount'] - datum['_increment_amount']",
"as": "_bottom_amount"
"calculate": "datum['Item'] == 'Gross Revenue' ? datum['Amount'] : 0",
"as": "_gross_revenue"
"calculate": "datum['Item'] == 'Net Revenue' ? datum['Amount'] : 0",
"as": "_net_revenue"
"calculate": "datum['Item'] == 'Gross Profit' ? datum['Amount'] : 0",
"as": "_gross_profit"
"calculate": "datum['Item'] == 'Operating Profit' ? datum['Amount'] : 0",
"as": "_operating_profit"
"calculate": "datum['Item'] == 'Earnings Before Income Tax' ? datum['Amount'] : 0",
"as": "_earnings_before_income_tax"
"joinaggregate": [
"op": "sum",
"field": "_gross_revenue",
"as": "_gross_revenue_amount"
"joinaggregate": [
"op": "sum",
"field": "_net_revenue",
"as": "_net_revenue_amount"
"joinaggregate": [
"op": "sum",
"field": "_gross_profit",
"as": "_gross_profit_amount"
"joinaggregate": [
"op": "sum",
"field": "_operating_profit",
"as": "_operating_profit_amount"
"joinaggregate": [
"op": "sum",
"field": "_earnings_before_income_tax",
"as": "_earnings_before_income_tax_amount"
"calculate": "datum['Amount'] / datum['_gross_revenue_amount']",
"as": "_percent_of_gross_revenue"
"calculate": "datum['Item'] == 'Returns' ? datum['Amount'] / datum['_gross_revenue_amount'] : datum['Item'] == 'Cost of Goods Sold' ? datum['Amount'] / datum['_net_revenue_amount'] : datum['Item'] == 'Sales and Marketing' ? datum['Amount'] / datum['_gross_profit_amount'] : datum['Item'] == 'Research and Development' ? datum['Amount'] / datum['_gross_profit_amount'] : datum['Item'] == 'General and Administrative' ? datum['Amount'] / datum['_gross_profit_amount'] : datum['Item'] == 'Cost of Interest on Debt' ? datum['Amount'] / datum['_operating_profit_amount'] : datum['Item'] == 'Income Tax' ? datum['Amount'] / datum['_earnings_before_income_tax_amount'] : null",
"as": "_percent_of_previous_statistic"
"calculate": "_percent_target == 'of Previous Statistic' ? datum['_percent_of_previous_statistic'] : datum['_percent_of_gross_revenue']",
"as": "_percent"
// label arrays
"calculate": "datum['Amount'] < 10000 ? format( datum['Amount'], '.2s' ) : format( datum['Amount'], '.3s' )",
"as": "_label_amount"
"calculate": "isValid( datum['_percent'] ) ? datum['_percent'] < 0.2 ? format( datum['_percent'], '.1%' ) : format( datum['_percent'], '.0%' ) : null",
"as": "_label_percent"
"calculate": "[ datum['_label_amount'], datum['_label_percent'] ]",
"as": "_label_array"
"spacing": 30,
"vconcat": [
"name": "LEGEND",
"width": 1180,
"height": 1,
"data": {
"values": [
"legend_id": 1,
"legend_size": 2,
"legend_label": "Statistic"
"legend_id": 2,
"legend_size": 1,
"legend_label": "Income"
"legend_id": 3,
"legend_size": 1,
"legend_label": "Expense"
"mark": {
"type": "arc",
"radius": 0
"encoding": {
"theta": {
"field": "legend_size",
"type": "quantitative"
"color": {
"field": "legend_label",
"type": "nominal",
"scale": {
"domain": [
"Statistic",
"Income",
"Expense"
"range": [
"#0F4C81",
"#217356",
"#7F2E42"
"legend": {
"direction": "horizontal",
"title": null,
"orient": "none",
"legendX": -60,
"labelColor": "black",
"labelFont": "Segoe UI",
"labelFontStyle": "italic",
"labelFontSize": {
"expr": "datum.value == 'Statistic' ? 14 : 12"
"labelFontWeight": {
"expr": "datum.value == 'Statistic' ? 'bold' : 'normal'"
"labelOffset": {
"expr": "datum.value == 'Statistic' ? 8 : 4"
"labelBaseline": "top",
"symbolType": "circle",
"symbolSize": {
"expr": "datum.value == 'Statistic' ? 600 : 300"
"symbolOpacity": 0.7
"name": "WATERFALL",
"width": 1180,
"height": 510,
"encoding": {
"x": {
"field": "_item_id_type_name",
"type": "nominal",
"axis": {
"title": null,
"labelAngle": 0,
"labelExpr": "split( slice( datum.value, 5, 100 ), '|' )",
"expr": "slice( datum.value, 3, 4 ) == 'S' ? 'bold' : 'normal'"
"labelFontSize": {
"expr": "slice( datum.value, 3, 4 ) == 'S' ? 14 : 10"
"y": {
"field": "_top_amount",
"type": "quantitative",
"axis": {
"title": "Amount",
"labelExpr": "datum.value == 0 ? 0 : format( datum.value, '.2s')"
"scale": {
"domain": [
0,
160000
"y2": {
"field": "_bottom_amount"
"layer": [
"name": "COLUMN_CHART",
"mark": {
"type": "bar",
"color": {
"expr": "datum['Type'] == 'Income' ? '#217356' : datum['Type'] == 'Expense' ? '#7F2E42' : '#0F4C81'"
"opacity": 0.7
"name": "DATA_LABELS",
"mark": {
"type": "text",
"fontStyle": "italic",
"fontWeight": {
"expr": "datum['Type'] == 'Statistic' ? 'bold' : 'normal'"
"fontSize": {
"expr": "datum['Type'] == 'Statistic' ? 16 : 12"
"yOffset": {
"expr": "datum['Type'] == 'Income' && isValid( datum['_percent'] ) ? -22 : datum['Type'] == 'Income' && ! isValid( datum['_percent'] ) ? -10 : 10"
"color": {
"expr": "datum['Type'] == 'Statistic' ? 'white' : 'black'"
"encoding": {
"text": {
"field": "_label_array"
Also included is the development sample PBIX using the synthetic dataset described above.
The intent of this example was not to provide a finished visual, but rather to explore the use of the Deneb custom visual and the Vega-Lite language within Power BI and to serve as a starting point for further development.
This example is provided as-is for information purposes only, and its use is solely at the discretion of the end user; no responsibility is assumed by the author.
Deneb Example - Financial Waterfall - V9.pbix (2.3 MB)
