Deneb/Vega-Lite can be used to add category enclosures to subcategory data in Power BI. These enclosures can be augmented with labels and values to increase the information presented.
I first saw an example of this last month in a post by Abacus Data on what Canadians think about Canada joining the European Union:
and specifically in this visual:
I thought Deneb/Vega-Lite might be a good candidate to apply a similar concept to survey data, and was introduced to the name “enclosures” by Anastasiya Kuznetsova in her recent post:
Further, in the past couple of days, I also saw posts by Kevin Flerlage and Daniel Marsh-Patrick applying a similar concept to an alternative to a stacked bar chart:
The example herein presents synthetic subcategory survey data with positive and negative category enclosures and values.
This example illustrates a number of Deneb/Vega-Lite features, including:
0 - General:
- a “title” block with subtitle
- a shared “transform” block with:
- a “calculate” transform to determine the ID (category ID * 100 + subcategory ID)
- an outside “layer” block for nested layers for category and subcategory data
1 - Category:
- a nested “transform” block with:
- 3x “joinaggregate” transforms to calculate the category maximum ID, the category minimum ID, and the category total percent
- a “filter” transform to restrict the dataset to only records for the positive and negative categories
- a “window/rank” transform to rank the subcategories by category
- a “filter” transform to restrict the dataset to only 1 record each for the positive and negative categories
- a nested “layer” block with:
- a “rect” mark with conditional colour (positive=green, negative=red) and 20% opacity
- a “text” mark for the category label (center alignment, rotated 270 degrees)
- a “text” mark for the category percent (right alignment)
2 - Subcategory:
- 2x “window/rank” transforms to determine the subcategory rank within its’ category
- 2x “calculate” transforms to determine the conditional subcategory opacity (positive=ascending, negative=descending)
- a “bar” mark with conditional colour (positive=green, negative=red, neutral=gray) and conditional opacity (as calculated in the transform above)
- a “text” mark for the subcategory label (right alignment)
- a “text” mark for the subcategory percent (left alignment)
Deneb/Vega-Lite JSON Code:
"title": {
"anchor": "start",
"align": "left",
"offset": 20,
"text": "Power BI Category Enclosures using Deneb",
"font": "Verdana",
"fontSize": 24,
"fontWeight": "bold",
"fontStyle": "normal",
"subtitle": "Synthetic Survey Data",
"subtitleFont": "Verdana",
"subtitleFontSize": 16,
"subtitleFontWeight": "normal",
"subtitleFontStyle": "italic"
"data": {
"name": "dataset"
"transform": [
"calculate": "( datum['Category ID'] * 100 ) + ( datum['Subcategory ID'] * 1 )",
"as": "_id"
"encoding": {
"y": {
"field": "_id",
"type": "nominal",
"axis": null
"x": {
"field": "Percent",
"type": "quantitative",
"scale": {
"domain": [
-0.15,
0.50
"axis": {
"values": [
0.0,
0.1,
0.2,
0.3,
0.4,
0.5
"labels": false,
"ticks": false,
"domain": false,
"title": null
"layer": [
"name": "CATEGORY",
"transform": [
"joinaggregate": [
"op": "min",
"field": "_id",
"as": "_category_min"
"op": "max",
"field": "_id",
"as": "_category_max"
"op": "sum",
"field": "Percent",
"as": "_category_percent"
"groupby": [
"Category ID"
"filter": "datum['Category'] != 'Neutral'"
"window": [
"op": "rank",
"as": "_subcategory_id_rank"
"groupby": [
"Category ID"
"sort": [
"field": "Subcategory ID",
"order": "ascending"
"filter": "datum['_subcategory_id_rank'] == 1"
"layer": [
"name": "CATEGORY_BAR",
"mark": {
"type": "rect",
"cornerRadius": 8,
"yOffset": -49,
"y2Offset": 49,
"color": {
"expr": "datum['Category'] == 'Positive' ? 'green' : 'red'"
"opacity": 0.2
"encoding": {
"x": {
"datum": -0.15
"x2": {
"datum": 0.45
"y": {
"field": "_category_min"
"y2": {
"field": "_category_max"
"name": "CATEGORY_LABEL",
"mark": {
"type": "text",
"align": "center",
"angle": 270,
"fontSize": 24,
"yOffset": 50
"encoding": {
"text": {
"field": "Category"
"x": {
"datum": -0.12
"name": "CATEGORY_PERCENT",
"mark": {
"type": "text",
"align": "right",
"fontSize": 18,
"yOffset": 50
"encoding": {
"text": {
"field": "_category_percent",
"format": ".0%"
"x": {
"datum": 0.44
"name": "SUBCATEGORY",
"layer": [
"name": "SUBCATEGORY_BAR",
"transform": [
"window": [
"op": "rank",
"as": "_subcategory_rank_asc"
"groupby": [
"Category"
"sort": [
"window": [
"op": "rank",
"as": "_subcategory_rank_desc"
"groupby": [
"Category"
"sort": [
"order": "descending"
"calculate": "datum['Category'] == 'Positive' ? datum['_subcategory_rank_asc'] : datum['Category'] == 'Negative' ? datum['_subcategory_rank_desc'] : 1",
"as": "_subcategory_opacity"
"calculate": "1 - ( datum['_subcategory_opacity'] * 0.4 )",
"mark": {
"type": "bar",
"cornerRadius": 8,
"height": {
"band": 0.7
"color": {
"expr": "datum['Category'] == 'Positive' ? 'green' : datum['Category'] == 'Negative' ? 'red' : '#C9C9C9'"
"opacity": {
"expr": "datum['_subcategory_opacity']"
"name": "SUBCATEGORY_LABEL",
"mark": {
"type": "text",
"align": "right",
"xOffset": -10,
"fontSize": 14
"encoding": {
"text": {
"field": "Subcategory"
"x": {
"datum": 0
"name": "SUBCATEGORY_PERCENT",
"mark": {
"type": "text",
"align": "left",
"xOffset": 10,
"fontSize": 14
"encoding": {
"text": {
"field": "Percent",
"format": ".0%"
Also included is the development sample PBIX using, as noted above, synthetic survey data.
NOTE: This was a quick-and-dirty development effort, and the first method that worked for each design element was left as-is; this prototype could undoubtably benefit greatly from refinement, but as the point of this effort was to produce a proof-of-concept, design enhancements are left as exercises for further development.
The intent of this example was not to provide a finished visual, but rather to explore the use of the Deneb custom visual and the Vega-Lite language within Power BI and to serve as a starting point for further development.
This example is provided as-is for information purposes only, and its use is solely at the discretion of the end user; no responsibility is assumed by the author.
Deneb Example - Category Enclosures - V4.pbix (4.6 MB)
