I am writing to understand if it is possible to configure the AutoSize property while using hconcat in Deneb Visuals.
I attached an example making some changes in Data from Deneb course.
My goal is to create a bar chart and display the value of each bar on the right and all those vertically aligned values.
I find a way but to do that, but I’m not finding a way to make the size of the chart responsive.
Is there a way to do that? Demo - Deneb - Theory_sc.pbix (1.7 MB)
Looking forward to keeping learning this great tool
Thanks Greg for your immediate answer, I read over Vega-Lite this: “Currently, Vega-Lite does not support shared axes for concatenated views.” Concatenating views | Vega-Lite. In the solution I implement with layer, I guess the problem is the XOffset with a fixed number. I try to find a way to define the XOffset by the end of the left layer but I couldn’t.
I’m also trying to learn Vega and see if it works with Vega.
It helps, thanks for your help @Greg. I appreciate your support and I took your idea and made a few adjustments that I feel I can easily use for different scenarios.
I look forward to learning more about Deneb with all the content you share with us. eDNA Forum - Deneb Bar Chart Right Data Labels_v2.pbix (1.7 MB)
