Thank you for your always support. I am trying to create a clustered bar chart as on the picture and in the PBI attachment and I almost achieved this using Deneb. However am having a problem with order/sort for the base measure. Where the small group values should be on top of the bars for positive numbers and on the bottom of the bars for negative numbers as on screenshot. Could you please advise if it is possible in Deneb?
Thank you very much for the reply. I think i tried this and it is not working for negative numbers (yellow for example should be after red one). I am attaching also orig excel screenshot.
Hi @vazik. I must be misunderstanding your issue. Please prepare an Excel table with the rows in exactly the order you want them displayed; perhaps that will help identify the issue.
