Deneb - Clustered Bar Chart / Comparison with Label and Total
I have a question about creating clustered bar chart for comparison using deneb.
I need to show the label value and total for each chart for example like this:
Kindly need your help for this case.
Thank You,
Yusuf
Question Deneb Add Label in Clustered OR Comparison Chart.pbix (5.5 MB)
Hi @yusufkurniaromadhon.
You’ll need 2 different marks in a layer, one for the bar and one for the label. The wide range of the values in your dataset makes a comparison difficult, nevertheless here’s an example:
Here’s the code:
  "data": {"name": "dataset"},
  "repeat": {
    "layer": ["Scope", "Done"]
  "spec": {
    "layer": [
        "mark": {
          "type": "bar",
          "tooltip": true
        "encoding": {
          "x": {
            "field": "Month",
            "type": "nominal"
          "xOffset": {
            "datum": {"repeat": "layer"}
          "y": {
            "field": {
              "repeat": "layer"
            "type": "quantitative"
          "color": {"field": "Tenant"}
        "mark": {
          "type": "text",
          "color": "black",
          "yOffset": 10
        "encoding": {
          "text": {
            "field": {
              "repeat": "layer"
            "type": "quantitative",
            "format": "#0",
            "formatType": "pbiFormat"
          "x": {
            "field": "Month",
            "type": "nominal"
          "xOffset": {
          "y": {
            "field": {
              "repeat": "layer"
Hope it helps.
eDNA Forum - Deneb Clustered Column Chart Text Labels.pbix (5.5 MB)
Hi @Greg
Well noted and thank you.
Regards,
Yusuf
