I have a question related to gauge creation in Power BI using Deneb.
The gauge has been created as attached.
I need to align the number in the category with the volume inside the gauge.
As you can see in the picture above, 70% in the category is not aligned with 70% in the volume inside the gauge.
How to fix this one?
Should I edit in these lines?
Or formula in “fill” color? eDNA Forum - Deneb Radial Gauge Range Labels EDITED.pbix (1.7 MB)
Thanks for making the new thread and attaching your work-in-progress PBIX.
Unfortunately, your issue is still not clear. If you’d like further assistance, please create a marked-up screenshot of the visual showing your desired outcome.
I want the value in red color match with the background scale that I created.
But as you can see in the screenshot, to have 70% in the background, I have to guess manually in “calculate” that 70 = 35.25.
If you can help with the formula, it could be great.
HI @yusufkurniaromadhon. OK, I took another look at your file and it remains unclear what you’re looking to achieve; the numbers you list look like they are already calculated:
We’re spinning-out-wheels here trying to describe what the issue is. So, to move forward, perhaps create a series of marked-up screenshots of the Deneb visual, noting in each case exactly what you’d like changed; you can also use PowerPoint or Excel if that’s easier.
I have commitments for the rest of the day, but will take another look tomorrow if there’s any update.
I just made the following changes to your transformations. Note that the calculation for _arc_total_radians did not change, but I had to place it before the modified calculations so that they could refer to it.
